Guys w/ auto and G-techs
Have you noticed if brake-torquing causes the G-tech to start measuring prematurely?
I got a 7.45 second g-tech reading with a power-brake versus 7.15/7.18 with just "stabbing" it.
Doesn't make sense, the 7.45 run felt a lot faster but ended up a lot slower.
Just curious.
-Steve
Just curious.
-Steve
Re: Guys w/ auto and G-techs (Pacin'California)
I'm going to make some runs Saturday. Will let you know. I know that when I torque it up, I get so much wheel spin that stabbing it gives me the best times.
Re: Guys w/ auto and G-techs (jaybird81)
g tech is a new device that measurs the "g" forces in your car with an accurate time. by having thoes 2 figuers it caculates your top speed, and your 1/4 time.
drag strip in a box.
just add a cop free and safe 1/4 mile
chad
[Modified by 71'AirStrike, 12:53 PM 9/10/2003]
chad
Re: Guys w/ auto and G-techs (71'AirStrike)
I've had mine start if I just banged on the throttle to hit my stall RPM. Try being a bit slower about reving the engine with the brakes on.
Cruise-In IV Veteran
Re: Guys w/ auto and G-techs (LAvetteman)
i hate those stupid things. it said my car was a 13.4 @ 103mph reality.. 13.98 @ 99
piece of garbage if you ask me
Re: Guys w/ auto and G-techs (Turbo-Jet)
it would start running the clock and not stay on go. If you power brake it or whatever, just see if it still reads go. If it does then it has not started to time.
THe G-Tech is only as accurate as the surface you test on. It is fairly accurate. :cheers:
Re: Guys w/ auto and G-techs (Corz)
Corz: you have to realize that the unit does not measure reaction time and it also measures the speed at the end of the 1/4 mile not the average speed throught the traps. That could explain the differences you are experiencing. :cheers:
