Wire colors?
Wire colors?
Anybody know the color coding on the wiring to the steering column on a 68? I purchased a new Flaming River steering column. I need to take the plug off my old column and put it on the new one.
Re: Wire colors? (Indy Year 25)
You need to contact Jim Shea. Here's a reply he had for a turn signal harness.
http://forums.corvetteforum.com/zerothread?id=645640
:seeya
:seeya
Re: Wire colors? (72GACRZR)
:seeya
:seeya
This matches what Flaming River gives for the harness on the column (I don't have the buzzer, or the door switch on the 68).
20 gage black - from horn relay - hot
20 gage light blue - left front lamp
20 gage dark blue - right front lamp
14 gage brown - from hazard warning flasher on fuse block
14 gage purple - to directional signal flasher
20 gage yellow - left rear lamps
20 gage dark green - right rear lamps
14 gage white - from stop light switch - hot when you press on brake pedal
:seeya
[Modified by Indy Year 25, 7:24 PM 9/10/2003]
