1980 Jumpy Speedometer
Just replaced the Cruise Control transducer and have CC back, but also still have a jumpy speedometer. Since there are two cables, is there a way to check which one is culprit, or should I just go ahead an replace both???
Re: 1980 Jumpy Speedometer (azswede1960)
You should check the square ends of the cable for being rounded off, if that's not it, lube the cales as good as you can and make sure the cables don't have too sharp bends, that usually fixes 99% of jumpt speedos (a worn CC transducer will cause a jumpy needle too but yours is new)
Marck
[Modified by Twin_Turbo, 2:12 AM 9/9/2003]
Marck
To test, you'll really have to have 3 test scenarios.
1) New cable from tranny to CC xducer, old cable to speedo. (testing old xducer->speedo cable)
2) Old cable from tranny to CC xducer, new cable to speedo. (testing old tranny cable)
3) new cable for both (testing new xducer)
May as well just replace both.
-Steve
*edit* Marck is spot on - lube is frequently at fault. Grease em and the jumpiness will prolly go away.
[Modified by Pacin'California, 12:31 AM 9/9/2003]
-Steve
Re: 1980 Jumpy Speedometer (Pacin'California)
On my '80 4spd car that I used to have, it took one brand new cable to stop that "jumpiness". Car had about 94K on it when I replaced it. One other possibility is a worn plastic speedo gear, but it's usually the cable. :yesnod:
I bought one of the speedometer grease lube fittings from Mid-America. You disconnect the speedo cable, put the fitting in and pump in grease through a standard grease gun. Works really well. If it gets a little jumpy again I re lube it. I have lent this to several club members with good success.
Re: 1980 Jumpy Speedometer (gliot1)
I just took the cable off the back of the speedo, pulled it out, lubed it, put it back in and works great now. Easy job.
