carb and power brakes
i have a 73 with power brakes with a brake booster thats bad.
will this cause the carb to not run correctly (cutting out etc) as the vac line is connected?
all help appreciated.
cgotthardt@earthlink.net
Re: carb and power brakes (cmg1)
I would say yes. I believe the check valve is suppose to keep a bad brake booster from causing a problem with the carb, but anything is possible.
