Big Block hood question for 1970 Vette...
Does anyone know how much extra clearance a BB hood gives over the basic hood? Where does the extra space start in relation to the engine block?
Thanks in advance...
Cruise-In IV Veteran
Re: Big Block hood question for 1970 Vette... (Rottenrob)
I'm pretty sure it gives you about an inch worth of room over a small block hood
Re: Big Block hood question for 1970 Vette... (Z-man)
I've had both on my 71. I'd estimate 2 1/2 " starting about 4" back from the rad frame tapering to 0 just behind the carb.
Re: Big Block hood question for 1970 Vette... (flynhi)
:iagree: , I have the original LT-1 hood (in very rough shape) a 72 L-48 hood and just put an original '68 L-88 hood on this summer. I like the L-88 hood the best with the additional clearance and the cowl induction.
I'm trying to get an estimate of total clearance between the block and the underside of the hood to see whether I will have enough room to put a low profile, twin-screw S/C on my small block. I need to determine if I have to buy a custom cowl type hood, or if an original Vette hood of some type will work.
Re: Big Block hood question for 1970 Vette... (427basketcase)
OK - I'll check it out, but I need to reserve judgement until I get the new engine installed.
Thanks-
Thanks-
