CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN?
Old 09-06-2003, 08:04 PM
Oldguard 7
Oldguard 7's Avatar
Default CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN?
I am wondering if an electric fan(s) can be used to substitute the belt driven fan and fan clutch. I am aware on stock vehicles a belt driven fan is used with a fan clutch and also an auxillary fan inside the fan shroud. If this is the case, which electric fans are the best? Answers please.
Old 09-06-2003, 08:09 PM
mrvette
mrvette's Avatar
Default Re: CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN? (Oldguard 7)
Really the only limiting power is engine power, and size to a certain extent, on account of more limited air circulation room in the compartment....
the radiator has to be in good top condition too, so does the shroud, and also the alternator has to put out no less than 100 amps...so when idleing at night in traffic with the a/c on, the engine does not overheat....
so for about 95% of the vettes on the road, the answer is YES....
GENE
Old 09-06-2003, 08:15 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
I'm not sure which fans he's running, but Chuck Harmon has electric fans running GREAT on his '69 L-88. His setup includes and aluminum radiator, two fans behind the rad(in front of the motor) and one in front of the rad.
He may chime in, but his 550 hp car runs very cool.
-Steve
Old 09-06-2003, 08:44 PM
Jvette73
Jvette73's Avatar
Absolutly yes. Electric fans can replace and out do mechanical fans in just about any circumstance provided the right setup is used. Its not only what fan you use but also how you have it wired up to function. They do draw more on the charging system so usually its a good idea to upgrade that too. As far as what setups are best im not the best source for info on that. Some others will chime in to add opinions im sure.
Old 09-06-2003, 11:41 PM
Smokehouse69
Smokehouse69's Avatar
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm a beleiver in Dual Spal 11" fans from DeWitt's, Tom DeWitt is a supporting vendor of the forum and will go the extra mile to help you get you fans installed and working correctly. Spal's aren't the cheapest fans, but they are in my opinion the best. They are used on many European high performance cars. Drop Tom a line and tell him what you have and what you want, he'll point you in the right direction.
http://www.dewitts.com
Here's the fans I and many other forum members have purchased.
http://www.dewitts.com/pages/product...sp?ProdID=251/
[Modified by Smokehouse69, 10:43 PM 9/6/2003]
Old 09-06-2003, 11:58 PM
AlwaysWave
AlwaysWave's Avatar
Cruise-In III Veteran
Default Re: CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN? (Smokehouse69)
:iagree:
Old 09-07-2003, 01:01 AM
GDaina
GDaina's Avatar
I'm a believer in the stock radiator...in good condition, nothing wrong with it. Am running the stock BB rad, dual Spals, temp in the 533 cube is around 180.
[Modified by GDaina, 10:19 AM 9/7/2003]
Old 09-07-2003, 05:53 AM
427V8
C6 the C5 of tomorrow
427V8's Avatar
Default Re: CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN? (GDaina)
My 427 small block is kept cool with a stock brass radiator and dual flexalite fans.
I am going to upgrade to an aluminum radiator but on'y because I race it from time to time and it can't keep up.
But for around town, it's just fine
Old 09-07-2003, 05:59 AM
groovyjay
groovyjay's Avatar
I got Spal Duals and BeCool alu rad keeping my BB cool :yesnod:
Old 09-07-2003, 07:31 PM
0Tom@Dewitt
Former Vendor
Tom@Dewitt's Avatar
Thanks for the comments but the dual fan link doesn't work. Here, I'll try it. www.dewitts.com/pages/productdetail.asp?ProdID=251
Old 09-07-2003, 09:25 PM
R. Bruno
R. Bruno's Avatar
Default Re: CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN? (biltogo)
I would say yes but learn from my experience, get the Spal fans. I have the flex-lites dual fans with a new aluminum radiator. On hot with the AC on, it doesn't quit cut it. This aid, on dofferent cars, the cheaper fans seem to work ok.
Old 09-07-2003, 10:20 PM
markdtn
markdtn's Avatar
Default Re: CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN? (R. Bruno)
I have 96 dual fans and an aluminum radiator on my 69 and it works great!
To CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN?
Quick Reply: CAN ELECTRIC FANS SUBSTITUTE THE STOCK FAN?
