Strut Arm
Strut Arm
What is the trick to hooking up the lower strut arm to the Fork in the rear wheel bearing assembly. It seems as if the strut arm needs to be pushed forward a whole lot to fit into the fork. This is the fork where the shock mount bolt goes in.
Does the trailing arm need to be jacked up. ???
Got the bearing assembly in and all torqued down.
Thanks for any help guys.
:steering:
:steering:
Re: Strut Arm (Van Steel)
Thanks for the help guys. I Jacked up the Trailing Arm and with a little help form a tapered punch got them suckers lined up and in with no problem.
Ain't this Forum GREAT.
:steering:
:steering:
