Mystery sending unit
Cruising
While working on my starter in my 73 350, I noticed a sending unit above it in the engine. It reminded me of a late model oil sending unit. It has two posts and no wires to it or near it. I could not find any trace of it in my manuals. I have the factory mechanical oil gauge, still works.
Is it supposed to be there or could it be a old test item from a previous repair? Thanks.
Jon :confused:
Jon :confused:
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Re: Mystery sending unit (logans73)
I have it on the 74 but of course I have wires going to it. Actually only one but it is jumpered to both posts.
Re: Mystery sending unit (SnoDrgn)
It's an old pic but the only on I have showing it
What you probably found is the tem sender unit for the TCS [transmission spark control] system. First type of semi smog control along with the AIR system. Thad
