Cowl cleaning question...
Going to try and clean my 82 up this weekend, it’s been sitting under a tree for the past 6 yrs. My question is the cowl is full of dirt/crap, I pulled out as much as I could, if I use a hose and wash the dirt down the side of the inner fender wells will it washout or will I be filling up the inner fenders with the dirt.
A CI-6 Car Show Winner
Re: Cowl cleaning question... (Skyhigh)
I know on my 75 the cowl is totally seperate and filling the inner fenders would be a non issue. Try wiping that cowl down with some Mother's "Back to Black" great stuff!
if you dont like the looks of it after ya clean it, Eckles sells a ABS plastic wiper area cover that can be painted to match your car... i'm gonna order one and put it on my car...GM really didnt make that area that attractive to begin with
By the way, the part # for that cover is A5300 thru the Ecklers catalog
Boy, was I ever confused on this one. I thought you were referring to the radiator cowl :banghead: The driver's side should wash out okay, the passenger side is a different story. You will probably want to remove the kick panel and the vent door which will enable you to get in there and clean the junk out of the bottom, then wash it out.
