Brake Booster Vacuum
Re: Brake Booster Vacuum (Zealot-6)
Some Holley carbs have a large fitting on the baseplate for the booster line, but not all. If it does not have that fitting on your carb I would recommend that you install a fitting in a 1/2 inch spacer plate and put the spacer under the carb.
