Question for those using a chrome timing cover
Platinum Supporting Dealership
Did the timing cover you bought come with a metal strip (or any kind) with timing marks?
Mine didn't. What is the best way to create some kind of index?
Re: Question for those using a chrome timing cover (Chris@VetteFinders)
My timing cover didn't come with the indicator attached. It had an indicator that is bolted on with the cover. This works well with the stock damper but when I went to the Proform cover I had to ditch the chrome pointer because it covered the numbers on the damper cover. i went with a Tavia adjustable pointer. This is just a pointer without any timing marks so you have to read the timing from the damper cover. It works great when you're setting up an ignition curve and looks nice too. I believe you can get regular chrome timing indicators from Mr. Gasket or Summit. Take a look at my sig pic. i think you can see the cover and pointer. Good luck.
Be sure you're at TDC of compression when you align your tab and balancer. I had some that were off. I just did this on one of our engines and had the heads off,which made it real easy but not neccessary.
Gary
Gary
