need pictures of gkull's interior!!!!
i was told through the forum that gkull has sparco seats and a roll cage in his corvette,i also am buying sparco seats and putting a cage in my c3 in the next two weeks.i dont know how to get a hold of gkull so i can ask a few questions as well as get some pictures if possible,so gkull if you read this i hope you can help me out if possible???? thanks in advance
Re: need pictures of gkull's interior!!!! (stroked 76)
I'm kind of in a hurry right now to pack and go out. but somewhere on this forum under the FAQ section it has a bunch of pictures of when I first had the shop weld it all in.
Are you cutting holes through the body like I did? Originally I bought two Sparco ultra fiber glass seats. 12.6 lbs each. But then I had NO rear access. So I left the passenger seat in.
I was going to say that I probably got rid of 45 lbs tearing out the stock thick sound isolation, rear speakers and mounts, roll out cover & mounts. Also the drivers side belts and retractors. Then installing fireproof aluminum matting and fire retardant thin carpet.
[Modified by gkull, 8:38 PM 9/4/2003]
Re: need pictures of gkull's interior!!!! (gkull)
Her's a couple more - See how they put white metal tabs around the holes cut in the body? I siliconed them all in for some water proofing.
It really makes a stiff safe car that passes all race requirements. But it's not your drive to the store car anymore!
Come on boy's it's time to go out and play! :)
