Need cyl. head I.D. help
I found a set of SB World heads with a casting # 1-037, I'm not sure how to find out which head it is, I know they make several models... This is the engine I would be putting them on.... S.B. 030"bore, 9.0-1 C.R.,Comp. Cam XE256 camshaft, ballanced crank assembly,performer int w/egr and Q-jet.,stock #...882 heads, all ports gasket matched and flaws removed, new 400THM w/shift kit ,stock converter,2.5” duals w/ crossover. Any help or comments would be appreicated
:cheers:
Nick
:cheers:
Nick
Re: Need cyl. head I.D. help (stingraynick75)
have you tried their web site? http://www.worldcastings.com/
