Speaking of swingarms
St. Jude Contributor
I know my swingarms, bushing and wheel bearings are old. I am not hearing any strange noises from the rear end, but I would to be pre-emptive just incase. What do I need ot look for and how do I check the rear-end for wear/slack/whatever else can happen.
I replaced the rear leaf spring last summer so I know that is in good shape.
:confused:
:confused:
Premium Supporting Vendor
Re: Speaking of swingarms (RLaFarge)
jack the rear up. put your hands on 12 & 6 O'clock. push on 12 than on 6. if you have movement you may need to have your t-arms rebuilt. there should be very little to no play at all. do the same at 3 & 9 O'clock also. have some one do that while you get under the car and look at your side yokes for in and out movement. No more than an 1/8" on those.
Re: Speaking of swingarms (Van Steel)
Thank you so much for explaining that to me. If they are worn out, can I pull them and send the whole thing to you guys to be rebuilt?
Just for reference, they're trailing arms and not swing arms.
Swing arm is a kind of suspension design that has no means of controlling tire camber through suspension travel. (Swing axle, actually...)
-Steve
-Steve
I`ve got a little movement from the yokes,but that should be the normal play..
St. Jude Donor '09
Re: Speaking of swingarms (BB wowbagger)
I just replaced my old rubber bushings with poly,and theres some play in the trailing arm if i do the "12 `n 6" test.How much play is acceptable,measuring at the tip of the tire? :confused: :cheers: :cheers:
Mike :cheers:
Re: Speaking of swingarms (Pacin'California)
LOL.. I am so embarrased. I knew the proper term for them, just had a brain fade. I guess working on computers causes that after a while! :leaving:
Is it real hard to rebuild the T-arms? I want to as much on the myself as I can. It saves $$$ that I can spend on other things for it, plus it give me some knowledge. I saw a tool that pushed out the spindles for about $200 buck.
You can rebuild them as long as you understand the procedure(which isn't hard) You'll be better off investing in a 20 ton press if you don't have one instead of those spindle presses. You will need a setup tool or old spindle you can polish undersize, a 3/4-20 nut or spindle knocker to protect the threads,a good dial indicator, you'll have to make a setup fixture to hold the bearing housing completely still,and basic hand tools. Do a search to find more about this job. Let me know if you need any help.
Gary
Gary
As a fellow computer geek, I'd have to recommend you send them out to Van Steel. These guys are top notch and their bearings are more solid than what came out of the factory. :)
-Steve
-Steve
