Anyone have a pic of their TV and throttle cable hooked up?
I'm ordering a trans from BTO and it looks like my brackets for the TV and throttle will interfere with each other. Anyone have a close up picture of theirs-preferably an Edelbrock or Carter, because that is what I have. Thanks in advance.....Mike
Re: Anyone have a pic of their TV and throttle cable hooked up? (79VetteMike)
Check this out, its on a Demon.
there has been a little negative press on BTO as of late, you might want to talk to a local trans builder before you order.
Re: Anyone have a pic of their TV and throttle cable hooked up? (dman535)
I have talked to local builders, but no one wants to build a 200R4. :sad: I was going to go with the 700R4, but then decided to go with the 200R4 for ease of install, then one of the people at BTO talked me into the 700R4-until she talked to a guy that worked there and said I should stick with the 200R4. :cry
