What type and make of aluminum heads are you using with your hookes sidepipe car?
I'm on a mission to determine the best fit/performance choice aluminum header and hooker sidepipe combination for my 350 small block application. Installation comments very much welcomed.
Re: What type and make of aluminum heads are you using with your hookes sidepipe car? (74 vert)
I plan to go w/ AFR 335's on my BB next year. It's hard to beat AFR Heads, a buddy has on on his small block and loves them.
:cheers:
:cheers:
Re: What type and make of aluminum heads are you using with your hookes sidepipe car? (Corey 68)
I have Brodix Track1's that will be going in my car in the spring :D . I have not yet tried them with the Hooker sidepipes ;) .
