Frame restoration
jobberone
Frame restoration
Can you replace a 74 frame 350 with an 80 frame also with 350? Can't find this anywhere but I'm a newbie. Thanks for any help.
Re: Frame restoration (jobberone)
Yes you can as long as you get the rear axle for it. They changed the rear of the frame in 1980 for use with a Dana 44 rear axle. The mounting of this rear end is vastly different from the previous GM rear axle.
It would probably be easiest if you got a frame that had a complete rear end assembly since then you would not need any other parts.
I believe the halfshafts and trailing arms are the same so all you would nee would be the axle, leaf spring, and probably the sideyokes
Premium Supporting Vendor
Re: Frame restoration (MikeC)
the half shafts are a different length. 63-79 are all the same and 80-82 are the same length. Also the rear end, side yokes and spindle flange on the 80-82's are different. 63-79 half shafts have a flange mounted on one side and the 80-82 don't. Strut rod bracket is different along w/the strut rods. Rear spring is different too.
[Modified by Van Steel, 8:40 AM 9/3/2003]
Re: Frame restoration (Van Steel)
The gas tank was also relocated, but I have heard of people getting the old tank to mount in the new frame with a little work and fabrication.
:seeya
:seeya
jobberone
Thanks everyone. Sounds like it may be better to go with the proper frame but this could be doable. Would I have problems with proper driveshaft alignment, wheel/tires fitting properly, and handling problems due to abnormal geometry? Only reason I started thinking of this is I can get my hands on a restored frame complete with drivetrain. However not sure yet of suspension components fore and aft.
Yeah the tank changed in 78..... the rear of my 77 frame is vastly different from the 78 frame. I think it will not be to hard of a modification to make my tank work.
Listen to Van Steel... He's the man who knows the stuff!
