1970 Expansion Tank
1970 Expansion Tank
I hope that all of you folks out there will bear with me. I am just learning the inner workings of Corvettes. My 1970 had been wrecked in it's earlier life and I am trying to put it back together as close to original as my budget will allow. I have seen some references indicating that the 1970, automatic, with A/C did not use an expansion tank. Can anyone confirm or deny this for me. Thanks
Re: 1970 Expansion Tank (Apocolips)
My '72 auto,air, 350, didn't have one. Don't have my reference books handy, but that sounds right. If no one else chimes in, I will try to look this evening. :seeya
Location: The reason time exists is so everything doesn't happen at once
One way to check is to look at the inner fender walls (assuming that they weren't damaged and replaced).
If the car did not have an expansion tank you should be able to feel four small "dimples" where the tank would have been mounted on cars so equiped.
The L46 (350/350hp) engines from 1969 and 1970 did not have the tanks, while the base engine cars did. GM recommended that on cars without the tank the radiator be filled to no more than 3" from the top with coolant. The radiator in effect was also the expansion tanks for these cars.
Senior Member since 1492
Re: 1970 Expansion Tank (6t9l4t6)
My '70 didn't start out with an expansion tank but I added one soon after I bought it. I use the aluminum type as an "over-flow" type tank. The aluminum tanks aren't cheap, but the look good. It sure beat having the radiator vomit coolant all over the garage floor after a run.
You can barely see it in this old pic.
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
I know this is an old post but I’m putting everything back together after a new crate 383 and the small hose just below the rad cap that would normally go to an expansion tank I can’t remember where it connected. Can anyone chime in on this?
The following 2 users liked this post by PJO:
Bluesting70 (05-03-2021),
interpon (05-05-2021)
Really appreciate the response PJO. I’m not able to download the link though. I’m guessing the “puke” hose just ran down the side of the radiator for overflow? My stock rad shows a cold fill line if about 3 inches down from the top of the fill hole.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,324 Likes
Theres no reason to post to an 18 year old thread to ask a question. Please start a new thread.
