Holley Projection 4 Throttle Body Injectors....HELP!
One of my injectors went south (quit working) and I am going to replace it ....my question is...how do you get the injector out of the holder I have included a picture of what I took off the car.....I have tried to take a pair of pliers and gently pull on the injectors to see if they my slide out...but no luck :banghead:
Re: Holley Projection 4 Throttle Body Injectors....HELP! (vetteguy75)
The injectors are pushed in and sealed with a rubber O ring. Just grab the defector with channel locks and pull straight up. The injector will come out.
Is that one solid peice or are there screws holding the four cyl like injector holders, looks like four screws in the middle but don't know/can't tell what they do. Give Holley a shout tomorrow if not luck here.
Re: Holley Projection 4 Throttle Body Injectors....HELP! (GDaina)
lay something in the center of the TB as a flucrum and use a flat screwdriver to pull it up.
as for the holes, a fuel metering cover goes over it. 4 of them are for gas, the 2 outer most are screw holes. The fuel metering cover that screws onto it has the fuel pressur regulator on it.
[Modified by Twin_Turbo, 1:39 PM 9/1/2003]
THANKS!!!! IT WORKED! JUST GRAB AND PULL STRAIGHT UP!!! :cheers: :thumbs: :party: :party: :party: :party: :hurray:
