Power steering fade
4th Gear
Power steering fade
The power steering on my 77 fades. While the car is cool no problems but as the car warms up it fades. By the time it gets to normal operating temerature I have almost no assist. The power steering pump is brand new. Any ideas on what I should try next?
Re: Power steering fade (soupguy)
My first inclination is that the problem is located in your power steering pump.
One thing to keep in mind, as your power steering fluid heats up, it will become less viscous (thinner) and therefore can leak past close clearance parts and seals easier. However, your power steering pump should be putting out enough flow so that minor internal leakage (inside the pump, control valve, and/or the assist cylinder) does not cause a lack of power steering.
I guess you need to answer the following questions:
Did your power steering operate correctly (at temperature) before you replaced your power steering pump?
Did you replace any other steering parts?
Jim Shea
Jim Shea
4th Gear
Re: Power steering fade (Jim Shea)
The old pump didn't work at all. The only other things I replaced were new hoses. I'm concerned because while driving it's not a big problem but parking and pulling it in the garage is a bear. We recently purchased the car for my wife and I don't know how long the old pump was bad. I think the lack of the assist has already stressed the pivot joint for the tilt wheel.
