How to fix a floor board crack ?
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I have 2 really good cracks in my drivers side floor board. I think I did it by using the floorboard to help scoot me back in my chair and I am a pretty big guy. I need to fix and strengthen this area. If it was a flat section I would do 1/4 inch marine plywood and glass it in. But the area is not flat.
So, any ideas ???
So, any ideas ???
Re: How to fix a floor board crack ? (BSeery)
U didnt say so Sir, so I gotta ask; Is this a 'glass floorboard or a steel one like my '76? 'Glass should be EZ to fix, with all the products available out there, and steel shouldnt be a heck of alot harder........... If its 'glass just get yourself some Fibreglass repair (even plumbers like me use it!), or find yourself a good Welder to fix it if its steel.
CI 6-7-8 Veteran
Re: How to fix a floor board crack ? (tnt76vette)
Cruise-In VI Veteran
Cruise-In VII Veteran
Brian, mine was cracked too, I ground out the cracks and layed in several layers of mat on top and bottom. They have held without any problems for the last couple of years.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
How about adding a couple of layers of Glass and wire mesh underlayment, then glass the whole area over once again?
