Painless wiring
Cruise-In IV Veteran
Cruise-In V Veteran
Painless wiring
anybody rewire their vettes?
All the wires in my enginebay are CRAP. and I have so many things not working, and no clue where some wires go. So has anybody ever rewired their vettes?
Re: Painless wiring (Guru_4_hire)
Yes, I rewired the entire car, in and out, except the rear harness and the front lighting harness, both of those were modified through the years, but not actually replaced.....
but the engine compartment and pass compartment are ALL me....
but I don't know to what excent you neeed/want to go in rebuilding them....
bet things are not so messed up as you may think, but what you need do is untape the things, and see what's where, you can use late model wire loombs/coverings instead of tape....
lemme know what problems you have and I most likely can help....
GENE
GENE
Cruise-In V Veteran
Re: Painless wiring (mrvette)
Well my heater fan doesnt work, nor do my dash lights, wires are getting burnt and broken in places. Especially around my heater/AC area. the other side is ugly but passable for now.
on that heater/a-c blower....the wiring goes to a relay on the a/c housing above the header on pass side, there is a silver relay there, take out the two screws and pull it up top and look carefully at that baked out plug and the wiring, and maybe even the relay is fried...due to header heat...exhaust manifold...
need move the thing to top of the a/c blower housing, very carefully as you do't need shoving screws into the a/c evaporator and really screwing the pooch....
but those wires on my '72 were so bad, I just scrubbed up the relay and cut the plug off one wire at a time, and soldered the wires to the relay...messy looking with no plug, but it works, and no voltage drops either....
there is also two fuses for that heater blower, the one under the dash in the usual inaccessible spot....and one under the hood on driver's fender liner near the horney relay a white fuse clip with a 30 amp fuse is the high speed blower fuse...but for HIGH speed ONLY....that's the function of the relay on the housing mentioned above...
also check for proper grounding on the motors, but then the wipers might not work either....
GENE
I just completed the engine bay harness. Unwrapped the entire thing and made numerous repairs to broken, missing, improperly routed wires and connectors. My advise is to use the AIM in conjunction with a detailed wireing diagram. Be forwarned though...some of those diagrams are incomplete. My 72 GM shop manual schematic is missing the blower motor relay. A schematic helps with proper wire color, gage, and how many to what component...and the AIM helps with routing and connection. Also...learn to use an electrical meter. "Fluke" is one of the better brands. A meter that has an audible function helps trace wires with a little beep when used in the ohm setting. This way you can do it yourself without haveing to look at the read out. Soldering is also a good skill to have, for I never trust a crimped splice. If I can solder...I will.
Good Luck...take your time...
Eddie
Eddie
