Stainless steel park brake hardware????
5th Gear
I am replacing the park brake shoes and hardware on our 1977. I was looking into stainless steel parts. One supplier told me that there are no good fitting SS shoes on the market and another told me I should not install SS shoes with a SS hardware kit (he said when you put SS to SS the matal bonds together). What's you thaughts on this and what I should use.
Re: Stainless steel park brake hardware???? (77hub)
I tried to put on a set of SS pads and hardware from SSBC, but it would not fit because I put longer studs on my aftermarket spindles. The extra thickness of the heads of the bolts caught on the brake hardware, so I just got fed up and removed it all. I'll sell you the hardware and pads for $60.
5th Gear
Hello Mike, thanks for the offer. I just sent you an e-mail. Wouls that be Part Number A800 from SSBC?
[Modified by 77hub, 1:48 AM 8/30/2003]
