81 Fuse Box
Re: 81 Fuse Box (ElectronBlueC3)
The fuse box is way up behind the and to the left of the brake pedal on the fire wall. You have to open the door turn around and start like you doing a limbo...then lay on your back on the floorboard of the car with you head up under the dash and and look to your right and it is right there....in plain view silly. Good luck and before you try this ...get a tube of Ben Gay..as your back will be killing you after you get back up and out of the car...unless you pull the seats to get to the fuse box... :smash: :lolg:
St. Jude Donor '09
Re: 81 Fuse Box (81' Corvette Guy)
