quadrajet rebuild kit
Old 08-28-2003, 06:05 PM
camaroneil
camaroneil's Avatar
Default quadrajet rebuild kit
just got a quadrajet carb rebuild kit for my 77 vette,
is there anything i need to look out for when rebuilding it???????????
thanks,
neil
Old 08-28-2003, 07:11 PM
R. Bruno
R. Bruno's Avatar
Default Re: quadrajet rebuild kit (camaroneil)
Make a little stand for the carb by putting 4- 4 inch carriage bolts through a board in the same orientaion as the holes through which the carb is bolted to the manifold. Thread a nut down on each one so that you can place the carb on the bolts as if they were the 4 bolts that bolt it to the manifold. The trick is that with the carb on the bolts you can work the thottle linkage while you are working on it. This little stand is a great help.
Just take your time on the rebuild and be organized. Us a tray inder the stand and you will not loose any small parts. I did it for the first time about 11/2 years ago and it turned out great. Also consider Doug Roe's book on Rochester carbs. Good luck :cheers:
Old 08-28-2003, 10:36 PM
JB
JB's Avatar
St. Jude Contributor
Default Re: quadrajet rebuild kit (R. Bruno)
:iagree: I've found that laying each part down on a towel as you remove them is a great help. The terrycloth of the towel keeps the parts from rolling around and ending up on the floor, and you can lay them out in the order you took them off, which makes it easier to put them all back in the right order.
JB
Old 08-28-2003, 11:52 PM
RJR99SS
RJR99SS's Avatar
while you got the energy to rebuild it, be sure to adjust it as well.
I cant count how many times i've heard someone say that they rebuild their quadrajet and it still ran like crap, then they start claiming that quadrejets are junk. So i ask them if they adjusted it up after they rebuilt it; usually they say "uh....you can adjust them?"
Yep....yep you can. In fact i'd say most carbs that are rebuilt dont even need rebuilt, they just need an adjustment here or there.
Old 08-29-2003, 06:24 AM
Boofers
Boofers's Avatar
Ya don't loose any parts, work in an area that is not cluttered so if you drop something on the floor it will be easier to find.
http://www.corvettefaq.com/lars.asp
Old 08-29-2003, 01:30 PM
camaroneil
camaroneil's Avatar
Default Re: quadrajet rebuild kit (Boofers)
it's running ok ish,
it's just the gaskets look a bit tired,
would the fact that the temp is only going up to about a quarter affect the wot?????
i notice there's a vacuum pipe going to the top flaps on the secondaries,
it feels about the same acceration when cold as when hot,
neil
Old 08-29-2003, 02:21 PM
mvftw
mvftw's Avatar
My carb needs to be rebuilt, I also have a kit. But from what I have read from this forum, I'm sending my carb to Lars. He is supposed to be the Q-Jet man. I know I can rebuild it and it should work, but he knows the little stuff to look for that most of us don't know what to look for. I think he's worth the money, because if you screw it up (and that's very possible for all of us) your S.O.L.... Just my $0.02 worth...
[Modified by mvftw, 2:22 PM 8/29/2003]
Old 08-29-2003, 02:42 PM
camaroneil
camaroneil's Avatar
Default Re: quadrajet rebuild kit (mvftw)
i would,
but it's a long way to send it,
i've got a holley 600 and performer manifold i could put on if it all goes pearshaped,
neil
Old 08-30-2003, 04:15 AM
Stephen Irons
Stephen Irons's Avatar
Neil
You might want to think about buying the book "Rochester CArburetors", by Doug Roe. (Available from NCRS I know, and maybe places like Chaters, here in the UK) It's the "all you need to know", and very detailed.
And, as has been said, lay everything out carefully, and preferably, take digital pics of everything BEFORE you unbolt anything!
Good luck.
To quadrajet rebuild kit
Quick Reply: quadrajet rebuild kit
