How do tell if your rear mono-leaf is worn out ??
I'm assuming there is some tolerance for ground-to-fender height. Or maybe it's just the bug to replace it with a higher spring rate
Re: How do tell if your rear mono-leaf is worn out ?? (Fast81)
If you are not able to get anymore ride height out of the spring. Or if the spring sits flat or with a reversed arch.
Re: How do tell if your rear mono-leaf is worn out ?? (LAvetteman)
Re: How do tell if your rear mono-leaf is worn out ?? (wcsinx)
All the ones I have seen still have a slight arch to them when parked. Maybe there was something wrong with them. :)
Mine was bowed the wrong way and fell appart when it was taken out :lol:
It was replaced with a glass spring and som shocks to match. :D
Chris :)
Chris :)
