Rear Main Seal leaking...will I need to remove the crank?
I have a stock 75 L48 with 50K miles on it. Is the rear main seal a two piece seal? Will I be able to replace the seal without removing the crankshaft?
[Modified by Rockn-Roll, 11:34 PM 8/26/2003]
Re: Rear Main Seal leaking...will I need to remove the crank? (Rockn-Roll)
Two piece seal. Crank must be loosened but not dropped. Pick up a Haynes manual for the procedure, its actually a very good resource.
Re: Rear Main Seal leaking...will I need to remove the crank? (FeedVaal)
I have removed only the rear main bearing cap before and used a small thin punch to push the seal out that is around the top of the crank in the block.
When you re-install the new seal over lap it in the bearing cap and the block.
Re: Rear Main Seal leaking...will I need to remove the crank? (James)
I just removed the rear main cap and punched it out with a brass punch. The seal also comes with a shoe-horn type type deal to keep from splitting the seal when re-installing it.
