5-SPEED Reserch
5-SPEED Reserch
WHere is the best place to go to do reserach on what 5 or 6 speed to put in my 1970 vette? I hve dont serches here and i cant find much info ( mabee i am doing the wrong search). i would like to get rid of my 411 gears and get the same performance with better gas milage on the hiway.
Thanks!
you guys are great!!
Thanks!
St. Jude Donor '03 & '05
Re: 5-SPEED Reserch (greg7097)
Use the forum search function and look for words like:
TKO, Richmond 6-speed, etc...
Re: 5-SPEED Reserch (DGT76)
http://www.keislerauto.com/
:thumbs:
:thumbs:
Re: 5-SPEED Reserch (GrandSportC3)
Greg,
I have a Tremec 3550(similar to the TKO) in my '68 with 3.73 rear end.
The first gear is Numerically higher so it gets off the line easier.
5th gear is a .66 overdrive so when you used to do 3K RPMs you now do 2K.
One of the best mods I think you can do. I love cruising at 65MPH at 2200RPM!
Keisler would be the solution for you without changing the diff.
They also have a version for higher power output but the overdrive is .85.
:cheers:
:cheers:
Follow this link:
http://forums.corvetteforum.com/zerothread?id=387542
You'll find loads of links with great deal of information there. :cheers:
:thumbs:
:thumbs:
I've checked into this and found this company....
http://www.5speedtransmissions.com/index.html
same great tranny.. MUCH lower price then Keislerauto.com
I'm ordering one this winter (if I keep the vette) :steering:
Re: 5-SPEED Reserch (69Rat)
Got my Keisler on order and should be here first of September.
TKO is the way to go! The TKO I installed is by far the single best mod I made to my car. The Kiesler kit looks real good but it is expensive, you can install the TKO yourself for at least $1k less.
They require that you remove all the bolts from the bellhousing and slide it down over the clutch so that you can install the transmission without cutting the crossmember. While I agree that not cutting the crossmember is an admirable benefit, there is much more increased difficulty when it comes to clutch replacement on the Kiesler system.
They do have a very cleverly designed shifter that comes out in the factory location though which is also of some benefit.
Re: 5-SPEED Reserch (fauxrs)
Here is a link to the forum how to install a T56.
http://temp.corvetteforum.net/c3/gwhite75/
Re: 5-SPEED Reserch (Alwyn678)
. :iagree:
. :iagree:
Thanks!!
Its going take me a week to get thru all this info!
But at least i know i need to get rid og my 411 gears and change to 336 gears
SO i can keep working on my frame off ( cant do the rear without the rear end)
