where do you find inside skins for the C3 Door
im looking for inside door skins, mine are gone on the bottom thanks to mud on the bottom, looking to replacing them, any help???? :confused:
Re: where do you find inside skins for the C3 Door (bnytro)
Just about every place carries them. Ecklers, The Last Detail, Gruhala.
You may change your mind when you see the prices :)
Pat
Pat
If you're talking about the insert that goes between the door panel and the metal skin of the door you can make new ones with sheet plastic. the caulking that the factory put on the door to secure this piece can be used as a guide
If you are talking about inside door panels, I have a pretty good set of black used ones off of my 79 Vette. If you are interested let me know by sending me an email at dmonsmail@yahoo.com. I live in Kailua so you would not have to pay for shipping. Check Vette catalogs to see what these cost new.
HTH :seeya
HTH :seeya
Re: where do you find inside skins for the C3 Door (DMONSVETTE)
no not the door panels, im looking for the steel inner door, would like a fiberglass replacement instead :steering:
