Header Gaskets Recomendations
Re: Header Gaskets Recomendations (theandies)
At first I used Mr. Gasket Header gaskets but I kept blowing them out so I switched to the copper header gaskets. They cost more but I haven't had a problem with a blown header gasket since. :thumbs:
I use copper on both the header and collector gaskets. No more leaks or blow outs. Also, you can remove the gaskets and re-install repeatedly.
Re: Header Gaskets Recomendations (TedH)
Percy's Aluminum Gaskets
http://www.percyshp.com/66sbchevsqr2.html
Re: Header Gaskets Recomendations (Alwyn678)
