Aluminum Water Pump
Aluminum Water Pump
I'm looking to replace the water pump on my 77 and would like to go with aluminum. I am looking at the Stewart product line. If I understand them, the Stage 1 line is cast iron with part number 13103 being the correct application. The Stage 2 line is aluminum with part # 23103 being the correct application. Stage 2 indicates that they are high flow. I have read that high flow is not necessary for a fairly stock engine and can even decrease the cooling moving the water through the radiator too quickly.
Can someone comment on this and any other aluminum water pumps that would provide good value? I've also been looking at the Edelbrock Victor Series. I ran across an article by Hib Halverson where he was high on these units. The GMPP aluminum water pump got good marks as well, though I can't find that one anywhere. Do you just go to the Chevy dealer?
Bob
Bob
Re: Aluminum Water Pump (Bobchad)
On my bigblock I have a aluminum high flow TRW water pump and run it 30% overdrive as well. I also do not run a thermostat and have no problems with keeping my blown bigblock cool. In fact it sometimes runs too cool even on a hot day.
I like high flow everything including my oil pump.
Re: Aluminum Water Pump (Steve Grodin)
I went with the Elelbrock after trying to get the Stewart to work. Keept blowing out the gasket.
Re: Aluminum Water Pump (dath)
Another thing I noticed about the Stewart is that it requires a special thermostat. All things being eqaul between the Edelbrock and the Stewart, I think I would have to go with the unit thta doesn't require extra work.
It was the block to pump gasket. We contacted Stewart and they said they never had that problem. Sent the pump back and got a refund. Installed the Edelbrock with everything the SAME and haven't had any problems. That has been three years now.
tom...
Re: Aluminum Water Pump (Tom73)
Check out this page on the Stewart site:
http://www.stewartcomponents.com/htm...comparison.asp
it is a comparison of the Stewart water pump to their "leading competitors" water pump. Take it with a grain of salt as it was Stewart doing the testing, but it may point up some real differences.
tom...
tom...
