1981 Vette with LT-1 motor
Found a listing for a 1981 with a 350 LT-1 motor. Is this good, bad or neutal? Before I call and look stupid I would rather look stupid here. Any specific questions you would ask about this motor? Any info on the LT-1 would be appreciated.
Re: 1981 Vette with LT-1 motor (kaz1961)
70, 71, 72 for the early ones, C4s (not sure of the years) are the late model fuel injected versions. If it is an early one, the year the engine is spec built to will help determine value.
The oringal LT1 was a solid lifter, high-compression engine. No way the car would pass emissions (if you have them in your area).
Or it could be the 90's vintage fuel-injected LT1 as found in the C4, Z28, and Impala SS.
Re: 1981 Vette with LT-1 motor (Robert N)
As with any corvette purchase check the numbers on the engine. Very possible it is neither LT1. Some people will call a vette engine whatever happens to fly out the as..... I mean mouth just cause it sounds good.
