Where should the front speakers be?
My 77 has an aftermarket radio and 2 aftermarket speakers, in the back. Did these cars originally come with 4 speakers? If so, where were the front ones located - dashboard or kick panel? Thanks.
Re: Where should the front speakers be? (BKbroiler)
I just replaced the stock radio in my 77. It had an am/fm stereo with two front speakers. The speakers were in the dash. The pass. side was pretty easy to replace, the drivers side was a real PIA.
2 4X6 in the dash which can be mounted in the kick panels. I tried some experiments w/ Pioneer 4x6 in the kicks & it worked nice though little bass as expected. Good bass when mounted in doors.
Re: Where should the front speakers be? (Ganey)
I've got an aftermarket cd/radio and small amp tucked in underneath it. I have 2 in the dash, 2 in the kicks and a monster boombox taking up all the space behind the seats. I rarely listen to it as I'm always listening for whats going to break next.
I also have two speakers in the dash, and two speakers in the kick panels, with a boom box in the back. however, i turn mine up so i can't hear what is breaking next. :steering:
Re: Where should the front speakers be? (bmar)
How do 4x6s mount in the dash ('77) Are there brackets, or do they go directly screw into the dash material? (if anybody has said brackets, I'm in the market!)
-Chris
-Chris
Re: Where should the front speakers be? (RUXperienced)
2 brackets that screw to the upper dash pad,the speakers bolt to them.I had to locate a used pair,could not find new ones.
