C3 Forum Time Saver
C3 Forum Time Saver
As a service to the forum, I've compiled the answers to satisfy 90% of the questions posted here. Feel free to add your own:
"255/60/R15 BF Goodrich Radial T/As"
"1974 was the last year for big blocks"
"Check for frame rust"
"E-bay sux"
"ZZ4"
"Steeroids"
"Carfax doesn't work on vehicles built prior to 1981"
"Synthetic oil is best"
"Synthetic oil sux"
last but not least:
"This post should be moved to Off Topic"
"E-bay sux"
"ZZ4"
"Steeroids"
"Synthetic oil sux"
last but not least:
Re: C3 Forum Time Saver (Neo Fender)
This post should be moved to Off Topic :skep: :lol:
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
"I don't know, but someone that does will chime in shortly"
"Man it's your car, paint it whatever color you like"
"I can't believe someone would do that to a Vette"
:lol:
:lol:
Re: C3 Forum Time Saver (Fevre)
1. ported
manifold
ported
manifold
ported
manifold
I disconnected mine and the car still runs fine!
2. 195 is stock
185 is better
160 is cool
none is better
car wont cool without a thermostat
yes it will
no it wont
yes it will
no it wont
3. Probably not an L88 :lol:
MJ
manifold
ported
manifold
ported
manifold
2. 195 is stock
185 is better
160 is cool
none is better
yes it will
no it wont
yes it will
no it wont
MJ
Re: C3 Forum Time Saver (MNJack)
hose rims look :cool:
those rims sux ****
how much hp should my new intake add
do stickers under the hood really make more hp/tq
how much is my vette worth - $4 -6k, or a lot less than you think
why don't C5 owners wave - 'cuz
my DD says 500 hp but the dyno said 190 - yes dyno's are always low
those rims sux ****
Re: C3 Forum Time Saver (gdh)
1) go ahead, carve the bezel
2) it's original, don't carve the bezel!
3) buy another bezel and carve it
4) buy a bezel that's already carved
:thumbs:
:thumbs:
Cruise-In IX Veteran
Bridgestone and Nitto are the only two companies that make 17 inch tires that will retain the stock tire diameter around 27 inches tall.
Re: C3 Forum Time Saver (KevinZ)
Don't call it a cease fire, unless you want to be shot. :skep:
Battery drains are caused by the drainer box, pass side behind dash. (aka iterior light time delay)
If your suspension is worn 255's will rub on front.
We will revote on spliting the C-3 forum shortly. (Especially after this escapade!!!) :lol:
Vacuum diagrams are at this site
Electrical diagrams are at that site
Both are available somewhere
It's a leak, track it
It's a short track it
No, it's a valve
No it's a ground
No, it's a valve
No it's a ground
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In VI Veteran
:lol: :lol:
