Which torque converter should I use??
My question is what stall speed should I put in the car. I'm puttin in a Fastburn 385 in my 76. Its got an TH350 with 3.08s in the rear.
Thanks in advance.
Thanks in advance.
Re: Which torque converter should I use?? (Crickett)
385/TH350 with 3.08s in the rear.
The stock converter was terrible it wanted to tug the car off the line and I had to continually shift into neutral at lights. This one is acceptable and plenty of torque off the line without slipping around noticably.
I would not go with a lower stall speed from what little I know, but you should talk to the tech's. they reccommended this based on cam specs and other factors.
[Modified by Marc80, 11:38 PM 8/21/2003]
Re: Which torque converter should I use?? (Marc80)
i have a 355 with a big cam and I run a 2400 stall, which seems to have decent driveability/performance
i would really like a 2800-3000 stall :seeya
Re: Which torque converter should I use?? (Glutamine83)
[Modified by dath, 12:29 PM 8/22/2003]
Re: Which torque converter should I use?? (dath)
2400 too.
I assume its a street car, going higher would hurt driveability. Bigger convertors are for use with bigger cams & gearing in performance applications.
Plus, that Fastburn motor is probably making decent power at 2200- 2400.
[Modified by Jack71, 5:30 PM 8/22/2003]
Re: Which torque converter should I use?? (Jack71)
I went with a 1800 stall in my 78 with a stroked 388ci motor and 700R4 overdrive transmission with a lock up converter. I have 3:55 gears in the back...With the amount of torque I will be making, I believe it will stall around 2100 rpms anyway which is dead in my torque power band. I should enjoy it when I finish the vette and get it on the road.....
Neil in Tenn
[Modified by Nomad78SA, 9:54 PM 8/22/2003]
Neil in Tenn
