Transmission output yoke travel?
How much travel should there be on the tranny output slip yoke where it goes into the tranny case? I'm thinking that mine is binding when the drivetrain gets warmed up.
Re: Transmission output yoke travel? (carriljc)
you want .75 to 1 inch of the slip yoke outside of the transmission. With that much you should be just fine. If you driveline can expand more than that you may want to look eslewhere for a bigger problem.
Thanks. Any idea how much space there should be between the slip yoke forward end, and the tranny internals, when it is at maximum insertion?
Re: Transmission output yoke travel? (442olds)
Re: Transmission output yoke travel? (fauxrs)
OK, so as long as I have 3/8" to 7/16" of room between the forward end of the yoke and the tranny internals I should be ok. I'll go check that. Thanks again.
