Are Flowmaster Mufflers a simple Bolt-On??
After upgrading my intake, cam and headers, I think it’s time to upgrade the old stock mufflers. I have hooker headers, 2.25 pipes, true dual, no cat or smog, leading to stock mufflers.
I am thinking of putting 40 series. My question is whether these are simple bolt-on parts or will I have to go to a muffler shop?
Also, if anyone has pics of what the setup looks like after installed on C3, please post here.
Thanks in advance.
:cheers:
Thanks in advance.
:cheers:
Re: Are Flowmaster Mufflers a simple Bolt-On?? (desi)
I just installed a set of Flowmaster 40's on my '69 BBC vert, after a backfire incident blew my drivers muffler in half!
The FM's are not exactly a "bolt on" upgrade, (unless you like pipe clamps everywhere!), but a simple one. I already had 2.5" pipes, so getting the 2.5" FM's was an easy fit. The problem is, they are shorter then stock mufflers, so you need an extra piece of pipe to get them to fit to the tail-pipe correctly. Not a problem if you have a mig welder.. or if you want you can braze them on with a torch and braze rod.
I love the sound, but I'd recommend and X-pipe.. at idle in a drive through.. EVERYONE in McD's will be looking at you!!! :lolg:
Re: Are Flowmaster Mufflers a simple Bolt-On?? (69Rat)
I agree. They are an easy upgrade but not exactly bolt on. Mine were put on with an entirely new exhaust system since I was changing pipe size. Mine kind of hang down in plain sight but I've seen some tucked up.
Re: Are Flowmaster Mufflers a simple Bolt-On?? (Cookwithvette)
I also have a flowmaster question. I want to run 2.5" pipes into original 40 series but don't know If i should get center inlet/outlet, offset inlet/outlet, or offset inlet center outlet. I going to look for the mufflers at Carlisle and probably have an exhaust shop bend to pipes for me.
Thanks,
Kevin
Thanks,
Kevin
Hmmm, so I need to take them in. I personally like the tucked away look. Just want to see tailpipe coming out with 2" chrome tips...
Maybe someone else has more pics??
Re: Are Flowmaster Mufflers a simple Bolt-On?? (L-82kid)
I just installed the FM 40's this past weekend... mine are offset in / center out.... but you could easily do offset in/out as well. Mine tuck neatly under the car in the original location and exit via the stock holes. You have to fiddle with the hangers to keep 2.5" from hitting either the underside or the exit holes.. but it works fine. I'll try to take a couple pics when I get home.
:thumbs:
:thumbs:
Don't use smaller tips then the mufflers... it kind of defeats the purpose of a 2.25/2.5" exhaust..... I got a set of 2.5" stainless tips... they slipped right on the round downs out of the mufflers.... looks factory freash... welll... a little bigger.. and LOUDER!!! :reddevil
I installed FM 40's (offset in/out) and didn't have any real problems. I had them clamped up at first and then had the whole system welded. You can see in my sig pic how the drivers side hung down a little but after they were welded, they tucked up underneath nicely.
Re: Are Flowmaster Mufflers a simple Bolt-On?? (Fasteighty)
Re: Are Flowmaster Mufflers a simple Bolt-On?? (Glensgages)
Fasteighty, I'm thinking of Flowmasters for my '82 (gotta let that rip-snortin' Cross-Fire breath!!!!! :crazy: ), but I'm also adding headers and the Mid-America 2.5" stainless-steel kit, too. What pipes did you run 'TO' the FM40s???
My flowmasters were three chamber, which I think is series 50 ?
Check out the pics, they tuck in there snuggly:
The Mid-America 2.5" kit (not SS) that I purchased from a forum member
Can you give me any input as to whether I should get the M-A kit or not (good points/bad points, etc.) Is the M-A installation difficult, quality of the kit, etc. Additionally, what the chance of connecting the M-A pipes to headers; I know they're built to hit the OEM manifolds..... :confused:
I have the MAD 2.5" true duals kit on my '81 and the headpipes were welded to the OEM downpipes. You can measure(2x) then cut the MAD headpipes to fit your header collectors, but don't forget to have flanges welded to the ends of the MAD headpipes, first. I have Dynamax SuperTurbos out back...
