Engine Question
Engine Question
The '70 Vette I purchased had it's engine (L46 - 350/350) rebuilt by the previous owner. The line item details on the receipt include quite a bit of information, most of which I (sorta) understand. But, can someone help me with the following items:
* Bore & Hone V8 Cyl..020
* Regrind Pass./Lt. Truck Crankshaft.010
* Cam Shaft WOL-WG996 (is this a non-stock cam...it sounds like a different cam?)
Thanks.
Thanks.
Re: Engine Question (Motor City Vette)
* Bore & Hone V8 Cyl..020 .
Brand, type ?????
GM Stock pistons were TRW, Forged, 11:1 Compression.
* Regrind Pass./Lt. Truck Crankshaft.010.
Stock GM crank was forged steel. (Nice Crank)
* Cam Shaft WOL-WG996 (is this a non-stock cam...it sounds like a different cam?).
Could be an aftermarket. Brand, type ????
Proper GM cam is 3896962
Hope this helps.
Barry
I would check with parts stores for a wolverine cam, sounds like there number but wouldn't swear to it. :cheers:
