Upgrading misc. driveline parts/rear end
Now that I've picked up 100rwhp with the head swap, I am seriously considering ditching my 3.36 rear gears and stepping down to 3.08s. With my Richmond 5-speed, 1st and 2nd are almost useless now even with wide, Z-rated rubber out back.
If I decide to swap gears, I figure I should consider upgrading the associated driveline parts back there. Halfshafts/spindles/driveshaft/carrier, etc.
I know absolutely NOTHING about the rear ends in these cars. I have the stock BB halfshafts, u-joints have been replaced at some point and appear to be in really good shape, and I assume is the stock differential and carrier unit.
Any help would be appreciated. I want to stay with IRS and the stock-type suspension, so something that will bolt-in is appropriate for this application.
Re: Upgrading misc. driveline parts/rear end (WA 2 FST)
I don't think I'll be the only guy to suggest checking with "Tom's Differentials"- at least I think that's the name of his business. He's got a website & a bunch of top quality parts for the entire rear end of our cars, including a beefed up differential. He or his staff should be able to take care of any advise & parts you need. I wish I had the $$$ to re-do my whole set up w/ his stuff. :thumbs:
Re: Upgrading misc. driveline parts/rear end (Les)
Thanks, Les. I will do a search for the Tom's stuff. I am not in a big hurry, to be honest. I just spent some decent $$ on the engine parts, not to mention the trans/clutch stuff about 8 months ago. But I like to do my research well in advance, so I appreciate the input. :)
WA 2, Van Steel now has available the whole Tom's setup except for the 12 bolt. I just bought their 30 spline inner/outer axles and 3.5 inch halfshafts with the 1480 U-joints. It looks beautiful. With a rebuilt rear end and rebuilt trailing arms it costs about 3700. I went with offset trailing arms as well. Check out their website under additional kits on the pull down menu. If you would like some pics of mine I can send them to you. I will be installing everything over the next month or so. Bill.
What is the HP you're running and what are you going to do with the car? For street use and light drag racing the stock units will hold up to around 450 hp if I recall correctly. If you can rebuild the rear end yourself you can do some of the mods that Tom's does. If you're going to run it hard then you might consider the 12 bolt conversion if you have the funds. Tom's has gears made for them specialy by US Gear. I used a set of 3:73's last year and was pleased with them.
Re: Upgrading misc. driveline parts/rear end (gtr1999)
Gkull & myself both use Tom's stuff. I have been very pleased with their service and would buy from them again. You may also want to consider using halfshaft safety loops with the added power and Z-grip tires :yesnod: .
I have some pics of my Tom's stuff & safety loops on my website ;) . http://temp.corvetteforum.net/c3/mik...on/index.shtml
[Modified by SmokedTires, 12:42 PM 8/20/2003]
Re: Upgrading misc. driveline parts/rear end (SmokedTires)
Great info and pics (Smoked Tires) guys. :)
I am only at ~510+hp now (434rwhp recently dyno'd), so this is not an outrageous BB, but it is a solid 11-second capable car. I do not go around dumping the clutch, and if I did it would just fry the tires anyway as even the good Z-rated rubber is not going to hold. I do NOT plan to run slicks on the car.
Bill, let me know how your install goes. I already have VBP offset trailing arms that have been on the car less than 8 months. I also read that with the bigger halfshafts like you're getting, that Tom's says you will have to modify the battery box. I wonder what that's all about?
Anyway, sounds like you got the exact setup (30-spline, 1480 u-joint stuff) I was eyeing. Looks great. :)
Hi there, I'm making same kinda power on my BB (540hp/552tq) and I also have the 5 speed Richmond. I bought new Ring n Pinion kit from Ikerd's, it's a 2,73 so I hopefully will have some usage for the first two gears :lol: . I bought the carbon fibre 1/2 shafts from Van Steel and no that other have said VS stock Tom's stuff, I will have to look at some spindles! Keep us posted on what you'll end up getting. :cheers:
