early 70 will likely have 6 qts, later ones had 5 qts. :cheers:
:iagree:
The early 70 LT1 had a 6qt oil pan, that is why you could not get power steering early on. They then changed to a 5qt pan in late 70 to allow for the option of power steering. So if the LT1 is a 71 or 72 it is 5 qts plus the filter. If it is a 70, then would depend upon which oil pan. If it has P/S then it is the 5 qt pan.
