Wiring Gurus: Fusable Links and locations???
Anyone know where the fusable links are on a 79 (78 probably the same). I think I blew through one and knowing the general vicinity would be of assistance Thanks!
Re: Wiring Gurus: Fusable Links and locations??? (timbo79)
You will find them where the wires connect onto the starter moter,good idea to replace it if you find one blown.
Neil.
Neil.
A CI-6 Car Show Winner
The main fuse link is at the starter (10 gauge). There are 2 or 3 more at the firewall on the engine side where the main wiring connector is, and those are smaller, maybe 14 or 16 gauge.
Thanks You guys..... I was armed with a voltmeter to check the entire harness. My shop manual indicated three but the starter one is the one I could not trace. THANKS!!!!!
THANKS TO ALL WHO ASSISTED> Got the links in (by the starter) and all is well... It was a bonehead move getting the links blown, especially as I was installing a serp system, but all is ok in CA now.. Thanks again. (And now I know where they are!!)
