List your 3 Most Recent Fixes/Mods to your Vette
You guys really bummed me out with my last thread listing your biggest problems. So how about listing your most recent mods/fixes. So here goes, list em if ya got em...
1) Fixed weird lock-up problem with torque convertor. Switch adjustment at the brake. Phew!
2) Installed a slick Trans Temp Gauge. Looks good and gives me some confidence in the unti now.
3) 406 is 90% done! Heads ordered and lower end is being assembled. All forged with 6in rods and hyd roller cam.
Re: List your 3 Most Recent Fixes/Mods to your Vette (tnt76vette)
I am working on three nice improvements that will hopefully be finished tomorrow. So, will wait to report, but I am very excited about what I have in progress! :)
[Modified by OHSIXX, 9:59 PM 8/18/2003]
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: List your 3 Most Recent Fixes/Mods to your Vette (Jack71)
I have done a few lately, don't remember which were the most recent.
Headers, dual exhaust.
Transmission lockup-problem fixed
In the middle of:
Fuel injection install (mount computer, run wire harness, plumb new fuel lines. I have to remove 90% of the interior just to do the wiring and mount the computer)
TV made EZ cable for trans.( drop the damn trans pan again)
insulation for cabin area.
thermal wrap the exhuast pipes under the car.
Build ramps / lift for car.
In the middle of:
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Re: List your 3 Most Recent Fixes/Mods to your Vette (BSeery)
1. Rebuilt left side of dash with new headlight switch, tach board, a/c vents and dye vinyl.
2. Restored center dash/gauge bezel. Refinnished black paint, installed new a/c vents, cleaned lenses.
3. Installed all new body weatherstrips
1. New upper leather shift boot
2. New lower rubber shift boot
3. Re-painted black parts of ralley wheel center caps
Re: List your 3 Most Recent Fixes/Mods to your Vette (Crickett)
Work in Progress:
After most of the rear busted I have to install
New Halfshafts
New U joints for Halfshafts
New Rear End Cover
New Diff Yoke
Around $550. There goes saving up for sidepipes.
New Halfshafts
New Rear End Cover
New Diff Yoke
1. Interior Finishing Up (Work In Progress)
2. Flowtech Headers
3. A/C System Going In (Work In Progress)
:D
2. Flowtech Headers
:D
St. Jude Donor '08
1. new fuel pump :cheers:
2. new lower radiator hose :rolleyes:
3. some new chrome pieces :cool: :party:
1.) New water pump
2.) Replaced faulty alternator and faulty wiring causing problems
3.) In process of fitting true dual exhaust system
:D :D
1. Replaced both speedo cables and disassembled/cleaned crusie control unit.
2. Removed wiper/washer bottled and re-fabed leaky seal around pump motor. Of course NOW the dang pump doesn't want to work!? What the? Will check again soon....
3. Painted bump-stops on front and rear semi-flat black.....
That pretty much covers last Saturday..... :yesnod:
Re: List your 3 Most Recent Fixes/Mods to your Vette (Alwyn678)
1. DeWitts Aluminum Radiator with Spal Fan
2. Fixed the wiper door and grill.
3. Fixed the Astro Vent door in the rear.
1. New front suspension
2. New Front Brakes
3. New Heater Core :crazy:
all done this past week. This weeks work to include detail/paint remainder of front frame and firewall, new front trans seal, and hopefully install engine. :cheers:
2. New Front Brakes
