Finally found rough/high idle problem!!!!
Just when I was about ready to pour gas on it and torch the thing, I stumbled onto the problem. I had an aftermarket performance chip in it and switched back to the original. BINGO! It starts better, idles properly and doesn't shake anymore. Now it is a pooch again, but it runs smoother.
Re: Finally found rough/high idle problem!!!! (Magnum '82)
Forget the aftermarket chips and get one burned specifically for your set up, you will much happier in the long run. I would check out the C-4 forum for more info and you might find a place/person near you to do it.
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,238 Likes
Re: Finally found rough/high idle problem!!!! (Fevre)
No matter what you do to a 82-84 Corvette the intake manifold will restrict power.
There was a 2nd GM chip part # that supposedly improved drivablility and idle characteristics for the CFI engine. Finding one at a dealer might be a real chore I hear.
I guess I havent seen a reason for it as my CFI runs pretty smooth at any engine speed.
Brent...
Brent...
