Timing Question - Help !!!!
Old 08-18-2003, 12:46 AM
Tron79
Tron79's Avatar
Default Timing Question - Help !!!!
Can anyone tell me what might cause my 79 (350) to start quickly when cold, but do nothing but crank once it's warmed up?
I have about 500 miles on a fresh rebuild and I'm going insane trying to figure this one out. I let it get cold and it starts. Run it for ten minutes and try to start it - No Go... It cranks and after a few tries I smell gas, but it doesn't seem to be getting a spark.
Any thoughts??? Marc
Old 08-18-2003, 09:17 AM
wombvette
wombvette's Avatar
Default Re: Timing Question - Help !!!! (Tron79)
Most likely it is flooding. Look closely down into the carb for any gas leakage. Try holding the pedal at full throttle to start.
Old 08-18-2003, 10:17 AM
80Xflags
80Xflags's Avatar
Default Re: Timing Question - Help !!!! (wombvette)
:iagree:
Had the same problem with my carb when I got the car. It was running way too rich for whatever reason and I had much difficulty starting the car with a hot engine. After cleaning the carb, replacing all the seals, and tuning it up, the car started running much better.
:cheers:
Old 08-18-2003, 06:38 PM
dath
dath's Avatar
:iagree: You also may want to check to see that the carb isn't leaking fuel, but I don't know how to do that, maybe someone else will chime in...
Old 08-23-2003, 03:46 AM
Tron79
Tron79's Avatar
Thanks for the feedback. You were right!!! Since I don't know the Qjet too well and just couldn't figure this out, I took it to a local hotrod shop. There apparently was a spring missing off my choke and it would stick either open or closed. So, once the engine got hot, I was effectively trying to start the car with the choke on. Works great now - Thank you...
:cheers:
Old 08-23-2003, 04:35 PM
bigvette1
bigvette1's Avatar
Go get LARS paper in the CORVETTEFAQ section on setting up the Q-Jets or search the posts on adjusting the chokes. Chances are it is working but out of whack.
To Timing Question - Help !!!!
Quick Reply: Timing Question - Help !!!!
