Any tips on cleaning the exterior of a carb?
Old 08-17-2003, 02:36 PM
Chris@VetteFinders
Platinum Supporting Dealership
Chris@VetteFinders's Avatar
Default Any tips on cleaning the exterior of a carb?
I am reassembling the engine on the 79 and the carb looks like hell next to the nice clean motor.
:confused:
Old 08-17-2003, 02:41 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Default Re: Any tips on cleaning the exterior of a carb? (Chris@VetteFinders)
Dissassemble it and soak it in carb cleaner?
I got all the grime off mine with Simple Green and a rag, but that doesn't make it "shine".
You could always have a shop plate it... but there's bucks right there.
-Steve
Old 08-17-2003, 10:04 PM
Chris@VetteFinders
Default Re: Any tips on cleaning the exterior of a carb? (Pacin'California)
I don't want to take it apart, but it is off of the engine.
Anyone?
Old 08-17-2003, 10:07 PM
PRNDL
PRNDL's Avatar
Not taking it apart really limits your options, because you can't soak it or otherwise screw up the gaskets. Eastwood has carb paint, but there also I am not sure if they recommend using it on an assembled carb. MJ
Old 08-17-2003, 11:46 PM
battsup
battsup's Avatar
Default Re: (MNJack)
I'm gonna try the wheel acid we have at the dealership to see if it will clean it up.
Old 08-17-2003, 11:54 PM
Chris@VetteFinders
Default Re: (battsup)
I was just talking to someone that told me to plug up all the inlets and soak it in tidy bowl toilet cleaner. Apparently, that is an old trick.
:skep:
Old 08-18-2003, 02:30 AM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: (Chris@VetteFinders)
how do you plug all the inlets, some are as small as a pin head (idle mix slots, air bleeds)?
Old 08-18-2003, 02:32 AM
Shark Racer
Default Re: (BSeery)
And some are huge. (Throttle venturi)
Any harsh cleanser that gets inside the carb will ruin it.
-Steve
Old 08-18-2003, 03:03 AM
GDaina
GDaina's Avatar
get a set of heavy, heavy rubber gloves, a parts cleaner brush, a big bowl or pot, Permatex carb cleaner, and start brushing the outside. When done, spray some disc brake cleaner to rinse the outside of the carb. You should have a clean looking piece when you're done.
Don't get any of the carb cleaner on your hands...nasty stuff, but it works wonders.
Old 08-20-2003, 10:27 PM
Chris@VetteFinders
Default Re: Any tips on cleaning the exterior of a carb? (GDaina)
Hey george, who has the Permatex Carb Cleaner?
Steve, the only thing inside a carb I can think of that would be a problem is the floats. Gasoline is a solvent as well.
[Modified by Chris@VetteFinders, 10:28 PM 8/20/2003]
Old 08-21-2003, 12:17 AM
ROD NOCK
ROD NOCK's Avatar
Try any auto parts. They should have both solvents. :yesnod: :chevy
Old 08-21-2003, 12:38 AM
GDaina
GDaina's Avatar
Default Re: Any tips on cleaning the exterior of a carb? (ROD NOCK)
yea, any parts stores, Napa is a good source, stuff is not cheap, but it does the job.
Old 08-21-2003, 08:07 AM
Chris@VetteFinders
Yeah well, Discount and AutoZone don't have it. I will try Napa next. I was hoping to avoid driving around aimlessly. Doesn't look lke "any" auto parts store has it. (Permatex that is)
Old 08-24-2003, 11:14 PM
Chris@VetteFinders
Thanks guys, the carb cleaner did a good job!
:cheers:
Old 08-24-2003, 11:39 PM
Shark Racer
:cheers:
...right click, save as. :thumbs:
You used the Permatex? I may do that for mine when I get the chance.
-Steve
Old 08-25-2003, 06:02 PM
Chris@VetteFinders
No, couldn't find it. Used a couple different cans of generic carb cleaner.
Old 08-25-2003, 06:06 PM
GDaina
GDaina's Avatar
Daaaaah.....my mistake, I used NAPA's carb cleaner, that's made by Permatex, but says NAPA on the can...sorry, I just realized.
Old 08-25-2003, 07:08 PM
dath
dath's Avatar
The other thing I like to use (not sure how safe it is on carbs) is brake cleaner. It is good at removing grime since the cans spray really hard and have all kinds of cool chemicals in one can:D With carb cleaner, there's an added bonus that it seems to kill all kinds of insects nearly on contact, just don't tell the EPA:D
To Any tips on cleaning the exterior of a carb?
Quick Reply: Any tips on cleaning the exterior of a carb?
