77 turn-signal arm removal
My service manuals are pretty vague. 77 was one of the few years or maybe the only year that had the windshield wiper switch and turn signal on the same arm. On a car with tilt, telescopic wheel and cruise what is the procedure to remove the arm from the column/switch housing.
"How did the arm break?" :confused: "It is, just fix it" she said. :blueangel:
Re: 77 turn-signal arm removal (Dan Plett)
Thanks Robert
I gave it a try. Guess I'm not smart enough to "rotate up and pull out". :nonod: I'll try it again later.
If your free next weekend Hugoton is having a car show featuring Corvettes.
http://skyways.lib.ks.us/towns/Hugoton/index.html
Dan
[Modified by Dan Plett, 7:53 PM 8/17/2003]
Dan
I just went out and tried it and thats the way it works by rotate I mean turn it counterclockwise like you are unscrewing it but it only turns maybe a quarter turn and then pull out .
I saw the flyer at the store fri. about the show and I was going to try to get there. No need to bring the corvettes they allready have our two years covered.
Bob
Bob
