Plug wire routing on a 79
Do the wires from Cylinders 1&3 go above, through or under the motor mount? Also, do they go between the exhaust manifold and the engine, or on the outside of the exhaust manifold?
Pictures would be helpful!
Re: Plug wire routing on a 79 (adamw1979)
On my 79 I had to gently pull the boots off the plug wires to run them through the motor mounts, then push boots back on. Sprayed alittle wd40
on them first. Do a search in archives for plug wires to find more info.
Good Luck. HTH
:seeya
Good Luck. HTH
:seeya
