WHAT SPEEDOMETER GEAR TO USE???
I finally found a rear end to replace my busted one. I also found out that first gear was messed up at the same time the rear end broke. But parts are on the way. My PROBLEM is that the new gear is a 3.70 and my old gear was a 3.36 what kind and where do I find a new speedo gear? Thanks in advance. :confused:
Re: WHAT SPEEDOMETER GEAR TO USE??? (Corvettelvr73)
Zip sells 'em in all teeth sizes. You gotta know which one you need.
[Modified by bluevetteman, 7:12 AM 8/16/2003]
