Ball Joint Rivets
Ball Joint Rivets
Can someone answer what is probably a stupid question? What do you use to install the rivets in the replacement ball joints in the A Arms. Looking for ideas for a do it yourself mechanic to help with this project.
Thanks. :confused:
Thanks. :confused:
Re: Ball Joint Rivets (72obsession)
Those were origionally put in the A-arms when they were on an assembly line with a huge rivet press. New ball joints come with bolts.
Cruise-In VI Veteran
Cruise-In VII Veteran
If you are looking to maintain originality then check with the Corvette Parts houses. I know that I've seen them in catalogs. Getting the rivets shouldn't be much of a problem, finding a tool to install them with is another thing. I've never seen one.
Re: Ball Joint Rivets (Van Steel)
Van Steel has riveted ball joints on several Corvettes I have restored and has always done a great job for me.
Regards,
Mark Donnally
Regards,
Mark Donnally
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
I think Van Steel has a good deal, however I can't imagine how you would go about this job without removing both lower and upper A frames?
