Power to manual steering
4th Gear
I am converting my 74 from power to manual steering. I am looking for advice on how to make the switch. I figure I'll have to get a manual steering box, but I'm not sure if I'll need to change anything else such as other steering linkage components. I also need a new parking brake handle and associated hardware for the same car.
Thanks
Thanks
Re: Power to manual steering (Steve Jarman)
Steering box is the same for power and manual. You'll need a new pitman arm and relay rod with ball stud. Otherwise you should be good to go.
Re: Power to manual steering (sb69coupe)
The tie rod ends have to be move to the outer holes in the steering arms. The inner ones are for power.
Joe
Re: Power to manual steering (TTop Tony)
I just got through doing this last winter. All I had to find was the relay rod. My pitman arm fit fine.
Good luck.
Good luck.
Hey T-Top what bumper is on your 74?? Cool stinger hood :cheers:
I went with Steeroids system and a used serpintine belt set up. The conversion cost about $700 to $800 for the stock system and was about $1,200 for the way I went. I have not put mine on yet but hear it is WAY better than the stock system although a bit more costly.
